PHILIPS 40PFL7605/H12 image reversed 180 degrees
    Hello
    LED TV
    MANUFACTURER: Philips
    MODEL: 40PFL7605 / H12
    MODEL ADDITIONAL:
    CHASSIS: Q552.1e-LA
    Mainboard: 310432862933
    PANEL: SHARP LK400D3LA93 FSP
    T-CON BOARD: SHARP CPWBX RUNTK4323TP ZT
    SYMPTOMS: The image is upside down 180 degrees
    Fault description and takes actions:
    My tcon was dead and i brought one from store.
    The picture is very good , color size and all others is all good except that the image is turned 180 degrees.
    I tried the service menu to do with option code label and again .Panel display type on the sticker is 295 the same as in the service menu under the option display screen.firmware upgrade from Philps website and again the same.
    Otherwise the TCON module has eeprom but I do not have dump file him so I was not stabbed nothing to do with him.
    I do not know what to try on. If anyone has any idea
    Thanks in advance.
    Kostenloses Bilderhosting
    Re: PHILIPS 40PFL7605/H12 image reversed 180 degrees
    First off, Have you tried reseating the cables to the tcon? Give the contacts a clean too
      Hello
      Yes i have first clean and reseat the 2 tcon flat cables
        I had this problem once but it was the data on the mainboard that was wrong.
        In any case you could try to swap the EEPROMs on the T-Con.
        Is this a TV from somebody else? Could it be that they swapped the mainboard too? (one with the wrong firmware)
          Hello
          I have the new firmware from philips.com with usb
          and this troble is again the self.
          Eeprom dupm i cant find it on the web.
            Re: PHILIPS 40PFL7605/H12 image reversed 180 degrees "solved"
            Solved
            I have buy a new tcon board and picture is now ok
