Sharp LC-42X20E: What is "control board"?
  • asi6
    • May 2015
    • Spain
    Hello all. My Sharp Aquos 42x20E stop working. The led blink code is 2x porwer led and 4x OPC led. I found in this forum this is a possible failure of the main board and power board (I found no leaked or burned capacitor).
    Anyway, past week I take it to the official Sharp tech service in my city, fist they said that should be main board, today I went to talk with them about money and said the problem is the power board and the "control board". In the beginning I was about to change the main board by myself but now I'm not sure what to buy because I'm not sure what is the "control board". Any idea?
    They ask 200€ for a reparation. Worth it?
    Thank you!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Sharp LC-42X20E: What is "control board"?
    They are talking about the T-con board.
    I am dubious about their diagnosis TBH
    Either way it is cheaper to swap out boards yourself if that is what they are going to do. Component level repair is cheaper still.
    Either way I would get the set back and come here, We will guide you through finding out what boards are at fault and maybe even offer enough information for you to repair the boards themselves.
    You will of course at least need a multimeter
    • asi6
      • May 2015
      • Spain
      Thank You, I am going to do it by myself. I think I will swap boards
      • newtothis
        • Mar 2013
        • 1556
        • england
        Ok when you get it open take good clear pictures of each board, one of overall layout so we can see the boards connected together and close up good quality shots of any connectors so we can see the labels printed on the board.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
