LCD TV blank screen, stby light stays on.
    I have a Polaroid Model FLM-3732, the tv does not turn on, I checked the screen with a flashlight and it is totally dead. I remove the t-con to see if that helps but it did not. The power bottom works to turn the standby light on but it does not turn it off, it remains on. I check the standby voltage and I have 4 volts instead of the 5 volts, would that be the problem, and also, instead of having 12 volts on one cable out of the PSU it reads only 10.7 volts, other voltages are normal, inverter board has voltage as it does the tcon board.
    Re: LCD TV blank screen, stby light stays on.
    Picture of the power supply board?
