TV Model: Samsung LE40C630 (LE40C630K1W)
Main board: BN94-02747E
Power supply board: BN44-00340A
Main observations:
- Standby diode is enabled and the light is still
- nothing happens when trying to turn tv on
- ecery capacitors on PS board were replaced. I also get second power board - issues are the same.
- bottom of the main board is dirty (see pics)
Cable connecting main board with power board:
- when disconnected, backlight of the screen is turning on
- every pins on PS board has proper voltage
- "Power ON" pin has 0.7V
- when connected, voltage on every pin are jumping between 0.2-0.3V and their proper value.
- when disconnected, those values are still and proper
Cable connecting main board with touch board (IR + touch buttons)
- every pins has proper voltage (around 3.3V)
- while measuring IR pin and pressing buttons on remote controller, voltage is jumping from 3.3V to lower (depends on whitch button i press) - so tv reads remote commands
- the same thing is with touch buttons
So i think power supply board and inverter are good.
If i disconnect t-con board, issues are the same, nothing happened.
Can you please give some advices how to locate invalid parts?
Main observations:
