Sorry i was busy and middle of workshop move moving to bigger workshop with these boards i ordered 200 igbt mosfets of each from china i recieved mostly fakes please be aware dont trust what yo uget they out of spec parts best thing to do if you have a scrap board salavage test parts try them the fault you describing the parts you changed should cure it
Hello All, thanks for the valuables infos found on this forum. I repaired my TXP50VT30E that ran countless hours over its 12 year of service. I was not ready to let it go.
I replace the 2 rows of IGBT along with the two diodes, all shorted. None of the resistors nor the drivers IC were dead.
As mentioned somewhere about the bad contact made between the board ground plane and the TV chassis, these points were all covered by a black compound. Don't know if it's the result of the voltage across or a chemical reaction between tin and zinc, maybe both. It has been told that these could be the source of the failure. So I retin all of them, on the board and the chassis as well. Works fine so far for 12 hours.
Thanks again.
