Samsung UN55D6050TFXZA
  • ptd
    • Aug 2016
    • 13
    Hi!
    Current Symptoms: When plugged in, the backlight is off, the standby light blinks 2x5, then the screen flashes (When captured on video, the light seems to be coming from the top left corner of the screen). This cycle happens as soon as the unit is plugged in and repeats endlessly.
    What I have done so far: When I first got the unit, it did the same thing but I could hear a clicking noise during the cycle. I visually inspected everything and couldn't find any issues that were clear to me. I traced the noise to the power board, so I ordered a new one. The tv standby light pattern and screen flash still remain, but the new power board does not click anymore. After spending some time reading this forum, I unplugged the cable connecting the power board to the main board, then plugged the unit in. The backlight came on and remained on, so I assumed that the issue was with the main board. After getting a new main board, the problem is still present. I didn't want to bother you all with this, but trying to fix it on my own has proved to be a stupid mistake. The attached pictures are of the current setup with a new power board and new main board.
    Part numbers from ShopJimmy:
    Samsung BN44-00424A (PD55A1_BHS) Power Supply / LED Board
    Samsung BN95-00498B (S128CM4C4LV0.4, BN41-01662) T-Con Board
    Samsung BN94-05038G Main Board for UN55D6050TFXZA
    Please let me know if i should try to take better pictures or if there is anything else I can do to make this easier. Thank you in advance for any and all help, I really appreciate it!!
    Re: Samsung UN55D6050TFXZA
    What happen if the T-CON board is not connected to the main board?
    • ptd
      • Aug 2016
      • 13
      When the T-CON board is disconnected from main, problem is exact same, 2x5 standby light then screen flash
        So far your power supply board is OK based on the BACKLIGHTS come on and saty on when the cable between the Main board and the power supply board is not connected.
        It is possible that the replacement main board is bad.
        • ptd
          • Aug 2016
          • 13
          Is there a way for me to check my main boards?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            do these mainboards suffer bga soldering issues on the main ic?
            • ptd
              • Aug 2016
              • 13
              Is that something I could check? Or would a better picture allow you to check?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Probably like all these Sammy Led sets, a nice big UNHEATSUNK CPU probably very hot running ! Good fucking job Samsung pricks !
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  You should check what the Pson and Bl voltages do to help confirm the mb as being the issue, check them and let us know what they read in standby and with the Tv on.
                  • ptd
                    • Aug 2016
                    • 13
                    I apologize if this sounds stupid because I'm not entirely sure what I'm doing, but I don't know if I can get two readings because when I plug the tv in, the issue with the standby light blinking starts and I cannot press any buttons or change anything. Should I have all of the boards connected when I get the readings?
                    • ptd
                      • Aug 2016
                      • 13
                      With everything plugged in, the voltages would jump when the screen flashed, so i unplugged the power board from the main. With the backlight constantly on, I was able to see that Ps-on read 5.361. Before I could check the Blu_on, the backlight started flashing. It was a faster pace than the flashing with main plugged in though.
                      http://youtu.be/r85WC52bC-g
                        The backlights should be on steady when main board is not connected to the power supply board, should be no flickering.
                        If you search BC for 'Samsung BN44-00424A' you will see that bad LEDs can create cycling problem.
                        https://www.badcaps.net/forum/search...archid=7115176
                        • ptd
                          • Aug 2016
                          • 13
                          Thanks for your help, it sounds like the LEDs are the issue. I'll check it out later and report back.
                          • ptd
                            • Aug 2016
                            • 13
                            After taking apart the tv, I found this:
                            And after reading this thread https://www.badcaps.net/forum/showthread.php?t=34566& , I removed the bad LEDs. In that thread there is some confusion about replacing the LEDs but someone says you can just jumper them if there aren't a lot. I want to make sure I do this correctly, so would i just solder two wires to connect remaining LEDs and bridge the gap? Is there anything I should be aware of?
                            • Nick's Tvs
                              • Jan 2014
                              • 621
                              I am not sure if it is to late for this set, but might as well comment for others to know.
                              On this specific strip for this model, if you have 1 or 2 burnt LED's like you have shown in the pictures, then you more than likely have at least 10 more bad LED's on that strip that are shorted but are just not showing any physical damage.
                              Test them with a digital multimeter in beep mode.
                              You will need to replace all of those leds.
                              • Asraf Atb
                                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                by Asraf Atb
                                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                01-27-2025, 05:02 PM
                              • mrautom8
                                Samsung TV UN75H6350AFXZC main board schematics?
                                by mrautom8
                                Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                While relay is on, all voltage rails are present and steady (scoped) on main board.
                                I love a good logic puzzle but getting lost without any schematics.
                                No shorts on ANY capacitor main board.
                                Thermal camera shows 3.3V inductor getting warm instantly but...
                                10-19-2025, 06:32 PM
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • ygorsan
                                by ygorsan
                                🧩 Problem Summary:
                                • I
                                07-28-2025, 08:34 AM
                              • Lee M.
                                Samsung UN75RU8000FXZA bad main board?
                                by Lee M.
                                When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                11-08-2023, 07:46 PM
