Building a cheap ACF tape bonding machine
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Now that ACF tape is available to buy and doesn't cost an arm and a leg (it's still pricey, but 50m of tape for $80-something sounds fair to me, considering the size of a tab), i have decided to build my own bonding machine.
    The few builds i have seen use a commercial bonding head and that costs $3000 to $5000 - OUCH. I was thinking more like $50.
    I have read the datasheet for the Hitachi ACF tape and it occurs to me that the requirements are not very stringent - the tape should reach 160 to 180C for 20 to 30 seconds, at a certain pressure applied by the bonding head. A suggested temperature (305C) for the bonding head is also given in the datasheet, and the only requirement for the head's shape is that it must have an even surface where it presses down on the tab (duh). There are no slopes required as it is with soldering BGAs, temperature just needs to get up there as fast as possible, stick there for 30 seconds then cool down. So the design of the control circuit is also easier.
    I have already chosen my heating element (it's a surprise, you'll laugh) and completed the design of the control circuit - all that's left is making the PCB. There is no microcontroller and no firmware involved, it's all analog. The output drives a relay so any kind of heating element can be used, and the input is a normal type K thermocouple. Control is accomplished via a couple pots and switches. The circuit turns the heater completely off once the time set has elapsed, and can also run a fan if desired.
    Anyone else interested?
    A working TV? How boring!
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Building a cheap ACF tape bonding machine
    This looks a great project what are you going to use to align the tab bonds back up?
    • diif
      • Feb 2014
      • 6978
      • England
      Yeah, definitely interested, once my daughter's 18th is out of the way i'll have some spare cash to chip in on some tape if needed.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        A good lightsource and a simple microscope would be OK for this...
        TELEFIX
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          I have a HD webcam i bought for $3.50 at a yard sale. You can find cheap stick-on microscope zoom lenses on ebay. A few high brightness LEDs should do for light source.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Very interesting.
            1. Does the panel also have to be preheated so as to minimize the stress on the glass when attempting to bond.
            2. This one is a bit more difficult to explain.
            I believe though may be wrong that the adhesive has conductive particles in suspension within it and when sufficient heat and pressure is applied to the adhesive, a connection is made, top to bottom.
            The tracks on the panel have a certain height (thickness of track).
            The tracks on the ribbons also have a certain height (thickness of track).
            The applied pressure must be enough to make a connection between top and bottom tracks (A) but not between the spaces between each track (B). This is achieved because distance A is less then distance B.
            So would it be critical to know the amount of pressure required on the bonding head to complete the task successfully.
              • 31017
              the panels arent virgin, how do you clean them first? !!
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                The panels may need to be preheated locally only if the bonding heater is weak. Glass has a higher thermal resistance than copper, so if anything, the PCB bond will need more power than the glass one.
                As for cleaning, Hitachi says in their datasheet that the stuff will come off with acetone or toluene.
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  I might be interested in this and did look into it in quite some detail a while ago, one of the stopping points for me was sourcing replacement COF assemblies.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    Cracked panels...
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Pressure wise things aren't as critical as one might think, the only risk Hitachi mentions in the datasheet is the tape squishing and coming out the sides, which would make for a weak bond in the middle.
                      The way the tape works is it has microscopic strips of conductive material (gold for the tape destined for glass bonding, nickel for the one intended to bond to the PCB), which are significantly thinner than the spacing between 2 traces on the flex and panel. So shorting between traces is impossible.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        These Romanians and there improvisations.
                        In almost every forum, I find some smart Romanian doing something, that others didn't.
                        I'm from there as well, but left in 96.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          Well i saw an Indian guy presenting in crappy "HD" video (probably shot on a cellphone) a homebuilt ACF bonding machine, so if some Indian guy can do it, so can I.
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Agreed... If the saying "necessity is the mother of invention" was ever so appropriate, it would be for our great Romanian member Th3_uN1Qu3...
                            I'd give him my boards for re-work anyday over a so-called "professional" with $10,000 equipment.
                            Just look at Louise Rossman - what a filthy mouth and such shoddy work.
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              If you ask me that's all the work Apple gear is good enough for... shoddy work for a shoddy machine, from a shoddy company with shoddy practices!
                              Follow the white rabbit.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have picked up a broken Kenwood DNN990HD, with corrupted software(linux).
                                Another Romanian(Radu/Intel/Germany) helped me out on another forum, via Skype. He spent a couple of hours like three-four times, until we(he) fixed it.
                                This is in different field, but still applies that we make things happen.
                                When I was still in Romania, I have made my own satelite system from scratch(after the revolution), when I mean from scratch, that means from scratch. The only things, that I have picked up, it was the dish and a windshield wiper motor and course, the high frequency electronic components.
                                I have made a modified suspension link for my Mazda CX5, that nobody had made yet. I have lowered my SUV 3-1/2".
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  agreed... If the saying "necessity is the mother of invention" was ever so appropriate, it would be for our great romanian member th3_un1qu3...
                                  Just look at louise rossman - what a filthy mouth and such shoddy work.
                                  +1
                                  • spidey
                                    climbs
                                    • Dec 2012
                                    • 644
                                    • Cyprus
                                    Hi, is there any progress on this ?
                                    • Marian.Bella
                                      • 12
                                      • Netherlands
                                      I am also interesting about any progress, pictures, etc. ???
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        I am also interesting...
                                        https://www.badcaps.net/forum/showthread.php?t=58937...................
                                        @newtothis I am Anticipating your homemade-ACF-bonding-machine. post #116 and #147
                                        https://www.badcaps.net/forum/showth...259#post670259
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                          Building a Laser / Spindle Engraving Machine very challenging
                                          I have been trying to build this engraving machine for last few months it has very challenging to get the part together
                                          I had bought a very small engraving machine a few years and it sat in the box it came in because I could not find a reasonable priced laser controller and the same thing about the the motor controller ( plus the table was to small for what I want to do with it )
                                          I have some challenges about the machine controller as well because I want an offline function so I can run the project with out having a computer hooked to machine controller
                                          09-27-2020, 04:43 PM
                                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                        • triplefour
                                          LG 75UN8570AUD panel issue fixed with tape.
                                          by triplefour
                                          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                          07-17-2023, 10:22 PM
