42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
    Re: 42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
    Originally posted by vinceroger69 View Post
    i wasnt on about the circle more the tuner looks soldered to that board is that the board you have now ordered to swop?
    No, It's the logic board mounted underneath th 1 shown.
      the board you was jumping the pins on? just trying to make sure you have ordered the right board you need
        There is a pic. in post 14? or 15. Where I jumped 3 and 4
          well if you have ordered that board it maybe the wrong one but let someone else confirm, we was using the jumpers on that board to see which board was faulty which it points too the main board the one with the hdmi/tuner on hence peoples comments regarding the tuner but hey i could be totally wrong let someone else confirm which board you need to replace.
            Reecey said to order the main (logic) board.
            link [TM].pdf&mfg=Philips-Magnavox
              Go to pages 5 and 6. Item 2
                post 12 reece mentions mainboard? i class the logic board/tcon,the mainboard i class is the one with inputs ie tuner/hdmi scarts etc im only trying too make sure its the correct board saves you wasting time reece may see this thread soon and assure us which board needs to be replaced it maybe me wrong so dont order one just yet.
                  Did you get that link to work? THe board listed as no. 2 they call the main board. Why are electronic nomenclature so confusing? in mechanics we don't call a piston a wheel. lol.
                  Oops , already ordered. :-(
                    im a ex mechanic but hey thats getting more into electronics to with ecus/can bus etc etc so loads more to fault find lol , as i say i may be wrong hence why saying wait for conformation as to which board im more used to fixing lcd/not plasmas i was more concerened you waited ages if you had ordered the wrong board and you could of found the correct one in that time.
                      Mainboard-hdmi inputs etc.
                        just to make sure reece now hes ran the tests and the test patterns show up ok etc its the mainboard with hdmi/tuner thats at fault and will need to make sure board is for his country regarding the tuner etc thanks reece im still learning too.
                          I guess I'll have to check on another manual because looking at the 1 shown don't seem to have a tuner??? and the parts description calls it a LOGIC-main board.
                            the picture you circled that wrong lead in blue thats the board you need with the hdmi ports on (post 36) whats the part number from that board? we need the part number from the board in your tv so we know its the right one
                              Well, can't find a board so I guess I'll have to find someone who know how to test and repair it, or scrap it, :-(
                                Reeceyburger123, Would you perhaps know where Ican find out how to test and repair this main board? I can't find one anywhere.
                                  Find the schematic for it bud and get testing the regulators etc and fuses on the board. If not what is the model of the pcb ?
                                    Hi, Reecey, I've tried to find this board on any site I could find that has samsung manuals etc. but no joy, this is a real odd ball. It has 50+ caps, various chips and ic's etc. but no fuses and no recognizable no's on the board that makes sense (3 small paper tags). I'm attaching some pic's of the top of the board and 1 of the bottom which has a bar code and a no. I;m also sending pic of the logic that is screwed on top of it that has the regular type no.s.
                                    Hope you can help. Tessting of all these components if way above my pay grade. :-)
                                      pic 1 above the black heat sink whats that long number?
                                        That no. is 200-100-iv501b-ch rev c.
                                          on the top right main logic board it has the following no's
                                          model no. 42 hd wd w3 lm
                                          pcb no. LJ41-05078
                                          REV. R1.729 (08 03 26
                                          NO'S ON MAIN BOARD- TAG ON CABLE TUNER
                                          TD 1636EF / FGMP-2
                                          3139 147 269819
                                          0818 SV20 000000
                                          SMALL GREEN TAG 29C69C5C
                                          O81015
                                          SMALL BLUE TAG P0151-
                                          ge421axa2h
                                          bottom small green tag
                                          141668
                                          Tag under bar code bottom of main(tuner board)
                                          ptd5u1108b00104
                                          45 899 ksige21axa2h rev.01
