Panasonic SA-BT330 F61 and F76 error - *GOT IT FIXED*
  • witwe
    • Nov 2015
    I own a Panasonic SA-BT330 BLU RAY HOME THEATER SYSTEM
    When I try to power it on, it immediatly shuts down with the error F61 or F76.
    I have already done several repair attempts with the help of the servicemanual, some google solutions etc.
    I tried to repair the power p.c.b. (changed q2903 and q2902 as I could see a ripple voltage from there outputs and some fluctuations)
    I have also changed the Rectifier D5802 and the main cap, all to no avail.
    Then I have bought a ESR meter to test every capacitor without disassembling it.
    I found out that every cap on the powersupply has low esr values expect C5726 and C5798!
    Both are the same parts 10uF 50V.
    The C5726 is located under the heatsink.
    After disassembling it, it shows me less than half of its capacity (3,7uF)
    I have changed both of them and now the unit is working again!
    Yesterday I got another SA-BT330 for repair with the same issue.
    And there where also the caps C5726 and C5798 the problem causing parts.
    I hope this helps someone out, as I can find a lot of F61 and F76 problems with no solution on google.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic SA-BT330 F61 and F76 error - *GOT IT FIXED*
    Good job. I repaired 2 philips soundbars ( hts7140 and hts8161b ) just replacing all the capacitors on the boards + a fuse.
    Its alot of work but the result is worth it.
    • tmfit
      • Aug 2017
      • New Zealand
      Thank you thank you! C5726 and C5798 as above, both replaced to repair F76 shut off error on Panasonic SA-BTT755.
      Great Help
      Cheers
      P+ve
      • ronnocod
        • Nov 2017
        • U.K.
        Thank you for the pointer. My unit is a SA-BT735 but I thought the power supply may be similar if not the same. I tested both caps and found C5726 (under the heatsink) showed 2.15uF / ESR 23.3 Ohms whereas C5798 showed 9.46uF / ESR 0.38 Ohms. Changing the one cap solved my ‘Please Wait'/F76 error.
        • hifiguy
          Geoff Scott
          • Jun 2011
          • 12
          Great stuff. Thanks witwe, good find. Worked for me too!
          • multiwahn
            • Sep 2018
            HI all,
            had same problem. Could not find capacitor ....98, only ....26. (SA-BT230) Changing that one was enaugh. Thanks for the help.
            Besides.... In my eyes this is poor engeneering. The capacitor has to break after a while as it is placed to near to the heatsink. That way it's "fried" all the time and tends to dry out and loose capacity.
            I put it somewhere else on the board where it is cooler. That way it might hold out a little longer.
            • dl0341gnet
              • Dec 2018
              • Austria
              Originally posted by multiwahn
              HI all,
              • dl0341gnet
                • Dec 2018
                • Austria
                https://1drv.ms/u/s!Aj0Mc72lAgeBlCFSYp9W5g5JCWsJ
                https://1drv.ms/u/s!Aj0Mc72lAgeBlCCN_q4FdeeKmAjO
                • Varith
                  • Apr 2019
                  • Chile
                  Hi, I had same problem, I replace both capacitors and my problems seems disapear... now apears "please Wait" 10 times and then works god. thanks...
                  • MartinConnolly
                    • Feb 2022
                    • 11
                    Same fix worked for me too. SA-BT230 just clicking on then off. No error displayed. The C5798 cap is on the opposite side of the board to the heatsink. Replaced both and it all works fine now. I got a 330v shock from the smoothing cap, which seems to hold a charge for ever. Take care to discharge this with a 100k resistor before working on the board. Thanks a lot guys.
                    • nomoresonys
                      • 12325
                      • U.S.
                      be VERY careful, it's the fact that it doesn't take a huge amount of voltage to effect your heart and if there's nobody around who can do cpr, game over: "A man standing up to his chest in water was once killed by a voltage of only 50 volts (he was a working in a shipyard). This is exceptional. In general, the voltage would have to be above about 100 volts to kill. For low voltages like 100 - 300 volts, death is usually caused by the electricity shocking your heart into a state where it vibrates instead of pumping (fibrillation). It can't easily be started again without special equipment. For higher voltages, the heart usually stops completely but can be started again with thumps on the chest. Im this case, the usual cause of death is internal burns."
                      • hey8
                        • Nov 2012
                        Want to share some info regarding the oem10uF 50V caps (C5726 and C5798) ...
                        Looking for replacements, I found they are now obsolete. After some digging, I found suitable (if not better) replacement caps...
                        Panasonic p/n EEU-EB1H100S. Just installed the two new caps, and I'm back up and running!
                        Hope this helps anyone looking for a fix!
                        Cheers!
                        • BigPete
                          Panasonic Heatpump Dryer Repair
                          by BigPete
                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                          Unfortunately the whole machine has to come apart to fix it.
                          I have...
                          11-01-2025, 06:40 PM
                        • Andre Gilbert
                          by Andre Gilbert
                          11-20-2024, 08:52 PM
                        • cloo
                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                          by cloo
                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                          After doing a factory reset this problem was gone and the picture was back to...
                          01-06-2025, 06:02 AM
                        • howardc64
                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                          by howardc64
                          TV was fixed just after removing Samsung's rear snap cover.
                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                          Maybe PSU->backlight connector didn't have a good contact?...
                          07-23-2025, 12:34 AM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
