Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by satman54 View Post
    yes,it remains on
    Yes, I completely forgot about you, try it, just save your native dumps.
      Hello, I need a dump of U13, U16, U11
      Brand: Medion
      Model: MD31230 DES-A 65
      Chassis (plate or major components): VESTEL 17MB120
      Matrix/Panel (if child): VES650QNTA-2D-U12
      Other (notes): U13,U11 SPI 25l1606e NAND U11 29f4g08abaea
      Symptoms: The TV does not turn on, only the blue LED is on, no 5v on USB
      Sorry for my English
        Hello, I need a dump of LG 32LM637BPVA
        Main board :EAX68167602(1.0)
          Hi all, looking for dump file fof my lg tv
          LG 42LV4400 - UA
          Flash chip - MX25L6406E
          Also, if someone can tell me if i need to relock the chip once it is programmed or not. I havd dtatis bots 0x3C 0xFF 0xFF when locked and 0x00 0x00 and 0x00 whrn unlocked.
            Hello all, we have a Samsung UE55TU8500 4k model. It has picture but it's stucked a bootloop. I have expected a bios fault. MB type is BN51-02756. Bios chip is 25Q80VSIG. Is anyone have bios dump for this model please? Thanks
              25Q80VSIG - it contains the firmware for T-Con, disconnect the cable connecting the motherboard to the panel and try to turn it on like this, if the reboot disappears, then the problem is in the panel itself.
                hello, im looking dump spi for UN49MU6103K (25q40)
                  Post your non-working dump here, I'll fix it.
                    Hi lotas, accidently lost the dump and the memory was erased
                      It's bad that you didn't save your native dump.
                        i found it
                          i found it
                          This dump is working!
                            Lotas, i program with other dumo same model and version, the tv power on, led on, i can hear the sound when i press smart hub on remote, but i dont have video.
                              Hi Guys! I'm looking for dump from Panasonic TX-40cs630e.
                              Led light stays solid red after power on.
                                nglese
                                Good evening
                                I kindly ask for the dump contained in the nand of the following tv
                                Brand PHILIPS
                                Model 42PFL4007H/12
                                Chassis Q552.4E LA
                                Main code 705TQCL009001 313929716741
                                Nand Flash Brand Hynix H27U4G8F2DTR position 7SOA
                                  Hi guys, I need Samsung tv model ue48h6670sz spi firmware. The eeprom is winbond 25q40, 256 kb. Panel number bn96-31530. Thank you so much.
                                    25Q40 - 512 kB
                                      Probably it's my fault, part number is correct. Do you have it?
                                        And what is the panel number bn96-31530 ?, this number refers to the LVDS cable.
                                          I'm so sorry again. Should be this:
                                          cy-gh048cslv1h
                                          Thank you for your patience.
