Eeprom dump thread!
This is a sticky topic.
    Originally posted by Andreas_de View Post
    Here is a dump of a Samsung UE48HU7590: Board is HU8500 BN41-02257B. TV starts for 1 second with "Smart TV" logo and then turns off screen. No reboot loop. Maybe you can find here a defect in the SPI EEPROM. I added the second EEPROM which is behind the little black heatsink as well in the ZIP.
    issue solved. I got another motherboard BN41-02257B from an UE65HU8290LXZG BN94-08099E that works as well with the 48" display. I dont know if that is just luck but picture is okay.
      Hello to everyone i am looking for firmware
      Vestel 17mb170
      Panel number vesq500ndp-2d-n42
        Vestel 17mb170
        Check if the panel number is correct.
          Is ves500qndp-2d-n42 not vesq500ndp-2d-n42
            Good morning . I am really sorry is Ves500qndp-2d-n42 exactly .Any help please , i have problem with the bios . As it says memory running out and need to reset Tv goes on and off
              I need EMMC Dump for Sony Android TV KD-55XG8596 with Main 1-983-791-12.
              Can somebody help me?
                Here is a working dump of eMMC (Samsung) on Sony KD-55XG8596 1-983-791-12.
                https://drive.google.com/file/d/18X5...nclLW870i/view
                  Thank you! i will try.
                    Good morning, I come once again to ask for help to resolve the situation with this TV that needs to update the firmware, if anyone could send help I would appreciate it​
                    THOMSON 55UA6406W MOTHER BOARD 40-NT67ES-MAC4HG SOFTWARE:V8-NT67F01-LF1V378
                    THANK YOU
                      I'm looking for a dump for the LG PF1000U projector (chassis FM51E), (NAND Hynix H27U1G8F2CTR SPI_FLASH: MX25L8035EM2I, EPROM 24C256C).
                      There is no epk file available anywhere
                      This device attempts to turn on and responds to both buttons and the remote control:
                      It exits standby, runs the fans for 5 seconds, then spins them at 100% for another 5 seconds judging by the sound, and then goes back into standby.
                      The problem seems to be a corrupted NAND as it appears to me:
                      [ 0.110000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3.3V 8-bit)
                      [ 0.110000] redirect_size = 400000, redirect_start = 7c00000
                      [ 0.110000] Loading nand bad block info(00000000+00020000)...
                      [ 0.119000] Mstar nand-flash partition definition
                      [ 0.119000] mtd info: # of partitions = 23
                      [ 0.119000] Creating 23 MTD partitions on "NAND 128MiB 3.3V 8-bit":
                      [ 0.119000] 0x00000000-0x00020000: "bbminfo"
                      [ 0.120000] 0x00040000-0x00060000: "mtdinfo"
                      [ 0.121000] 0x00160000-0x00760000: "rootfs"
                      [ 0.121000] 0x00760000-0x007c0000: "lginit"
                      [ 0.122000] 0x007c0000-0x007e0000: "crc32info"
                      [ 0.123000] 0x007e0000-0x00800000: "model"
                      [ 0.124000] 0x00800000-0x00900000: "logo"
                      [ 0.124000] 0x00900000-0x00a00000: "cmndata"
                      [ 0.125000] 0x00a00000-0x01200000: "nvram"
                      [ 0.126000] 0x01200000-0x01300000: "user"
                      [ 0.127000] 0x01300000-0x01400000: "ezcal"
                      [ 0.128000] 0x01400000-0x014a0000: "estream"
                      [ 0.128000] 0x014a0000-0x01620000: "opsrclib"
                      [ 0.129000] 0x01620000-0x018a0000: "kernel"
                      [ 0.130000] 0x018a0000-0x03560000: "lgapp"
                      [ 0.131000] 0x03560000-0x04fa0000: "lgres"
                      [ 0.132000] 0x04fa0000-0x05be0000: "lgfont"
                      [ 0.132000] 0x05be0000-0x05c00000: "tplist"
                      [ 0.133000] 0x05c00000-0x07640000: "lgres"
                      [ 0.134000] 0x00080000-0x000a0000: "cert"
                      [ 0.135000] 0x000a0000-0x00140000: "authcxt"
                      [ 0.136000] 0x00060000-0x00080000: "hdcp2"
                      [ 0.137000] 0x00140000-0x00160000: "keyrsrv"
                      [ 0.138000] mod_nand_init is invoked
                      [ 0.138000] GE driver inits
                      [ 0.138000] mod_iic_init is invoked
                      [ 0.138000] model option = 0xfc
                      [ 0.138000] Mstar_emac: [PHY Addr] ==> :0
                      [ 0.138000] Mstar_emac: alloRAM_VA_BASE = 0xA0C40000 alloRAM_PA_BASE= 0xC40000 alloRAM_SIZE= 0x100000
                      [ 0.139000] RBQP_BASE = c44000
                      [ 0.140000] [SCALER][000173] _mod_scaler_init
                      [ 0.140000] [TTX_DRV][00508]init 170
                      [ 0.140000] MDrv_CC_Init
                      [ 0.140000] init 172
                      [ 0.140000] [DEMOD_DRV][00369]init 245
                      [ 0.140000] [BDMA_DRV][00629]init 251
                      [ 0.141000] TCP cubic registered
                      [ 0.141000] NET: Registered protocol family 17
                      [ 0.142000] RPC: Registered udp transport module.
                      [ 0.142000] RPC: Registered tcp transport module.
                      [ 0.142000] Adding user_initcall[0] = 0x803a1314
                      [ 0.142000] Adding user_initcall[1] = 0x803a1320
                      [ 0.142000] Adding user_initcall[2] = 0x803a66f8
                      [ 0.144000] VFS: Mounted root (squashfs filesystem) readonly.
                      [ 0.150000] VFS: Mounted lginit (squashfs filesystem) readonly.
                      [ 0.150000] Freeing unused kernel memory: 132k freed
                      [ 0.204000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock19
                      [ 0.225000] Empty flash at 0x000213bc ends at 0x00021800
                      [ 0.234000] Empty flash at 0x00023200 ends at 0x00023800
                      [ 0.242000] Empty flash at 0x00024bbc ends at 0x00025000
                      [ 0.250000] Empty flash at 0x000271ec ends at 0x00027800
                      [ 0.250000] jffs2_scan_inode_node(): CRC failed on node at 0x00028fe0: Read 0xffffffff, calculated 0x916f9a2e
                      [ 0.258000] Empty flash at 0x00029120 ends at 0x00029800
                      [ 0.264000] Empty flash at 0x0002ab84 ends at 0x0002b000
                      [ 0.289000] Empty flash at 0x00040878 ends at 0x00041000
                      [ 0.289000] jffs2_scan_dirent_node(): Node CRC failed on node at 0x000427f4: Read 0xffffffff, calculated 0x2322e93d
                      Thank you in advance!
                        sorry does anyone have the dump for this hitachi tv?
                        25L1606E thanks e nel caso va cambiato anche lo status reg?
                          25L1606E thanks and if so should the status reg also be changed?
                            sorry I didn't put the model, does anyone have the dump for this TV? HITACHI 32HB4W65I
                              What is the motherboard number, what is the panel number?
                                here they are
                                  Is the model exactly the same as hitachi 32hb4w65i? Because this model had a motherboard not 17MB110P, but 17MB140.
                                    HI, this are some little dumps from TV Sharp LC-40LE730E...
                                      ok lotas yes I sent you as you asked me tv model screen model and main number I'll send you everything again here
                                      tv model
                                      screen model
                                      and motherboard model
                                        tv model
                                        screen model
                                        I only have this dump.
                                          sorry lotas this is already ready do i have to change the status reg? in case can you tell me what the status reg is thanks
