Eeprom dump thread!
This is a sticky topic.
  • abbassi.diag
    • Jun 2018
    • maroc
    #141
    Re: Eeprom dump thread!
    thank you very much
    big work
    • David53
      • Aug 2013
      • 36
      I have a couple of questions I hope someone might answer. Can the eeprom be read and written too while still on the board or does it have to be removed from the board? Also what blank eeprom chip numbers do we need to keep to be able to program them? Thanks so much for any advice....
      David
      • comptek
        • Aug 2013
        • 606
        #143
        Can anyone point me in the right direction for a uk bush 32" led tv with DVD player built in, firmware for USB update if possible please model LED32DVDW intermittent operation have to unplug and plug back in for it to operate again with the remote thank you
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          #144
          Vizio V0370M Dump
          Submitted by ayhan yılmaz
          VIZIO VO370M
          Main board:3637-0502-0150(0G)
          Panel LC370WU
          FLASH:MX25L3205D
          U18
          • Zap45
            • Mar 2017
            • 3
            • France
            #145
            Good afternoon,
            i hope i write in correct section.
            My blaupunkt tv refuses to power on despite all voltages are present.
            So i think i can be a firmware brick!
            i'm wondering if it exists a way to re upload the firmware using usb port by using a specif key press in tv buttons or using remote control ?
            Many thanks to anyone that can explain me how to do if it is possible.
            Otherwise i plan to dismount the eeprom to flash it outside so that i need the eeprom dump.
            Firmware for this TV:
            main board is t.msd309.btu87 (4k tv)
            and panel display innolux v390dk1-ls
            see pictures for more details. about my tv set.
            Thank you for your help.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 950
              Here are good, tested working eeproms for a few Samsung TVs. Enjoy.
              • mjhera
                • Aug 2015
                • 3
                • Ireland
                #147
                Hi all, I am looking for an eeprom dump for a JVC LT-32C350
                Panel: LC320DXJ-SFE1
                Main Board: MS308C1-ZC01-01
                Any help would be appreciated
                • mjhera
                  • Aug 2015
                  • 3
                  • Ireland
                  #148
                  Hi all, here is the firmware for the JVC that I was asking for.
                  • mjhera
                    • Aug 2015
                    • 3
                    • Ireland
                    #149
                    Hi PROTOTYPE-1, Here you go.
                    • PROTOTYPE-1
                      • May 2018
                      • 3
                      • India
                      #150
                      Thank you very much mjhera
                      • huzo
                        • Sep 2014
                        • 181
                        • CROATIA
                        #151
                        hi i'm looking for a dump for vestel 17mb95m , panel is ves390unda 01
                        the tv is quadro,i tried a few dumps ,but i get only blinking led,one from finlux turns the backlight on,but nothing else...i put a new 25l1606 chip so i'm not sure if i need to flash something else on the chip except for dump?someone mentioned nand flash also?
                        • mutts
                          • Jun 2018
                          • 11
                          • United Kingdom
                          #152
                          I am after an eeprom dump for Toshiba 40L3453DB with mainboard 17MB95 and the panel is a VES400UNDS-2D-R7. The closest to working was with UPG20 files but screen was upside down and remote was no longer recognised. Many thanks.
                          • boujariss
                            • Jul 2018
                            • maroc
                            #153
                            Merci beaucoup, mon ami
                            • yohnsee
                              Semi-noob
                              • Dec 2017
                              • 198
                              • Hungary
                              #154
                              Hy folks,
                              my first contribute to this thread:
                              Blaupunkt B32SHE56TC (known also as 32/56i-gb-1b-hbkup-de)
                              Mainboard: T.MSD309.B21B, display: LC320WXN SC B1
                              Eprom: 25Q32
                              Cheers, Janos
                              • yohnsee
                                Semi-noob
                                • Dec 2017
                                • 198
                                • Hungary
                                #155
                                Blaupunkt BLA-39_68I-GB-1B-FHBKU-DE
                                Display: V390HJ1-L01
                                Chip: GD25Q32
                                Sorry, I can't gather more data on this device, because only the motherboard came to me.
                                Cheers, Janos
                                • trata
                                  • Jun 2018
                                  • 5
                                  • portugal
                                  #156
                                  17mb140
                                  • d2fx
                                    • May 2015
                                    • 24
                                    • french west indies
                                    #157
                                    I need the dump for coby ledtv3226 please.
                                    panel Samsung LTA320AN01
                                    best regards
                                    • d2fx
                                      • May 2015
                                      • 24
                                      #158
                                      here it is for Samsung and lg panel
                                      • d2fx
                                        • May 2015
                                        • 24
                                        #159
                                        ledtv3226 coby
                                        • sn4k3
                                          • Oct 2016
                                          • 68
                                          • Portugal
                                          #160
                                          Hello, anyone have the dump for:
                                          Blaupunkt 40/148i-GB-5B-FHBKUP-EU
                                          Chassis: TP.MSD309.BP85
                                          Model: B40A148TCFHD
                                          Product code: BA40I148BFBKPE061
                                          Label on LED screen:
                                          Model: 0040CA001
                                          LSC400HM06
                                          Regards
                                          EDIT:
                                          While searching and try out multiple ROMs i find one compatible with the model:
                                          Code:
                                          40/133I-WB-5B-FHBKUP-EU
                                          B40A133TCFHD
                                          BS40I133BFBKPE061
                                          MATRYCA  LSC400HM06
                                          PG TP.MSD309.BP85
                                          PAMIĘĆ 25Q32
                                          Not exactly equal at references but very similar, it works without problems so far.
                                          I will keep testing for a day or two and i will confirm
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
