Phillips LCD Model #42PFL7422D/37
  • Tayninh55
    • Sep 2011
    • 153
    I have this 42” tv, Phillips LCD Model #42PFL7422D/37, when you plug it in, it shows a solid blue power light, black screen (nothing on the screen), and then makes a clicking sound for a while, then shuts down (with no power light). I thought wow, easy fix, probably bad caps. Took the back off, cannot see any visible signs of bad caps (no bulging or leakage visible). I then plugged it in and turned it on to see where the noise was coming from, could see two different places that lit up and went back off with the clicking sound, on the main board. The noted lights (on the main board) came on and off with the clicking sound. Haven't checked anything else yet. Just took “my pictures” and quit for the night. Appreciate a little guidance as I'm not trained in this field, just trying to pick up a little knowledge as a hobby. Thanks!
  • Tayninh55
    • Sep 2011
    • 153
    Re: Phillips LCD Model #42PFL7422D/37
    Will this move my post to the top of the page?
    • maxvalutech
      • 804
      • australia
      You have standby voltage and tv is trying to turn on. You need to take all the voltages as shown near connectors on Power board and post the readings together with what the markings say e.g. ps-on etc.
      • Tayninh55
        • Sep 2011
        • 153
        Thank you for the info,,,,,,,,,,,,,,do you mean put the black lead on a ground (where a screw holds the board down) and then check each point where a wire leaves the power board thru the connectors with the red probe and record the voltage,,,,,,,,,,,with the unit plugged in?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Yes and when powered on.
          • Tayninh55
            • Sep 2011
            • 153
            Hi,,,,,I just got back to my tv. I checked for power at the ribbon that goes from the power board to the main board (with everything connected) and found no dc voltage at any of the pins. When I plug in the AC cord, the green lights (standby voltage, I guess) come on and the blue power light comes on. Then the green lights on the main board go out, and the blue power light goes out and turns to a red blinking light of six long and three short blinks. I had my wife plug it in, and there is still no dc voltage at that ribbon with the green lights burning on the main board. What does six long blinking red lights, followed by three short red blinking red lights indicate? Thanks!
            • dskall
              • Oct 2016
              • 2905
              • usa
              What connector did you check?
              Need voltages from connector that goes from power supply board to main board. Will need pin#-pin label-Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
              Format:
              Pin# - Pin Label - Pin Voltage standby - Pin voltage power on
              1 - XXXXXXX - XXv - XXXv
              2 - XXXXXXX - XXXv - XXXv
              3 - XXXXXXX - XXXv - XXXv
              4 - etc.
                We need the pictures of the whole backside of the TV showing all the boards and how they are connected together.
                You have two power supplies, the standby supply is on the main board, and then you have main power supply that is turned on by the main board.
                There are many version of this model so we need to know what trhe actual boards are being used in your TV.
                http://www.shopjimmy.com/catalogsear.../?q=42PFL7422D
                • Tayninh55
                  • Sep 2011
                  • 153
                  Seems like there were a lot of numbers on these boards: On the power board was 3104 303 50594 Then on a sticker was ES 730.3 002.C 0011407 and S310432848912 284912
                  Then on the main board: 3104.303.50842 D and 8204.004.58882 Hope these are what you need.
                  DISREGARD MY %6 post, I had a ribbon cable disconnected and did realize it at the time. My symptoms are still the same as in my first post.
                  • Tayninh55
                    • Sep 2011
                    • 153
                    OK,,,,,,here are the pictures of the back of the tv,,,,,,
                    • Tayninh55
                      • Sep 2011
                      • 153
                      It seems that most of the pins on these boards are not labeled. I plugged it in,,,,,the green lights (standby voltage?) came on for a couple seconds,,,,,then went off. I measured the voltage on the ribbon that goes from power board to main board AT the edge of the power board.
                      Pin furthest to the left I'll call #8 on the pic of the top of the board,,,,,,#8 pin will be the furthest to right on the pic of bottom of the board.
                      #8 0 Voltage
                      #7 0
                      #6 0
                      #5 0
                      #4 0
                      #3 4.0 Volts
                      #2 5.0 Volts
                      #1 0.1 Volts
                        Can I see the model number sticker on the back of the TV? I need the chassis number on that sticker.
                          https://www.badcaps.net/forum/attach...3&d=1490296060
                          Check the resistance of the resistor R3318 which is right next to the gray rectangular cap, you also need t check the capacitance of that grey cap.
                          • Tayninh55
                            • Sep 2011
                            • 153
                            OK,,,,,,here's the sticker on the back.
                            On the resister, can I just release one end of the resistor to check it,,,,,or should I take it out of the board completely?
                            On the capacitor, should I check it with the power plugged in, for DC voltage, and if so, how do I tell the polarity on it (don't think I've ever checked one like that before) I didn't check closely, but don't remember seeing polarity,,,,,I'll check again.
                            Thanks again for the guidance!
                              You can test it without removing the resistor, that resistor usually goes open circuit when it is bad, it usually has the value between 47~150 Ohms.
                              The grey cap that the resistor is connected to usually lose its capacitance.
                                OK, so it is 42PFL7422D/37 chassis # Q523.1U LA.
                                I will see if they have the service manual at elektrotanya.com
                                • Tayninh55
                                  • Sep 2011
                                  • 153
                                  I think you were right about that resister. When I checked it on 200 ohm scale, it flashed a number, then went to the 1 at the left of the scale, indicating that it's open. I have a continuity checker that beeps. Touch the probes together, and it beeps,,,,,,,,put a probe on each end of the resistor,,,,,and nothing.
                                  Not sure on the capacitor. Put meter on the 2000k scale and it started out at about 800, and slowly the numbers continued going up.
                                    Can you read the resistance as printed on that resistor?
                                    To check the capacitor you will need to check the capacitance, I do not know if your DMM can do capacitance reading or not.
                                      OK, R3318 per Q523.1U LA chassis, it is supposed to be 470 Ohms.
                                        BTW, this model is also known for having blown IC on the inverter boards and they need the modification:
                                        https://www.badcaps.net/forum/showth...ght=42PFL7422D
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • nickgronk
                                          iMac PowerPC G4 very low sound • Sunflower Model
                                          by nickgronk
                                          Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
                                          I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
                                          I cannot find any schematics...
                                          08-05-2024, 07:04 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Solvik
                                          XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                          by Solvik
                                          Hello
                                          i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                          All voltages are normal....
                                          02-13-2025, 02:43 PM
