Panasonic VIERA TC-L32X5 - One LED blink
  • WannaTheater
    • Jun 2017
    • 18
    Hi all- First post here. I have a Panasonic TC-L32X5 TV, that is doing the following:
    - Right half of screen is dark, "HDMI 1" is displayed, "No Signal" is displayed, then TV turns off, with the RED LED blinking on and off repeating (1 blink per repeat)
    With the back off, it looks like the following is happening inside the panel when the TV is turned on:
    1) Entire panel lights up (white LEDs? inside the metal casing, that I can see through holes)
    2) Right side goes dark
    3) Entire panel lights up a second time
    4) Right side goes dark
    5) Entire panel lights up a third time
    6) Right side goes dark
    7) TV shuts itself off
    From the service manual I found online, there are 3 boards - P Board (Power and LED driver), A Board, and K board (Remote, LED, Luminance Sensor).
    Also per manual, one blink equates to:
    BL_SOS - SOS from PANEL inverter. I am not sure if this is saying the panel is bad, or there is an inverter circuit that feeds the panel that is bad (perhaps on the P board?).
    I am capable of swapping boards, and there are a few identical P boards on eBay. I'm alse experienced with testing boards (voltages, diodes, etc), although I don't have a scope. I have the proper equipment to replace components. But I am just not familiar with the circuitry in these TVs.
    Any suggestions on where to look/try next?
    Or does this thing need to take a trip to the curb on garbage day?
  • WannaTheater
    • Jun 2017
    • 18
    Re: Panasonic VIERA TC-L32X5 - One LED blink
    I should also add that this TV was working fine about 6 months ago. I recently put a bracket on the back (VESA), mounted it on a wall, turned it on to find it didn't work. Not sure if it stopped working because it sat for a while without turning it on, or if hanging it up perhaps shifted the case on the back??/ (just guessing here now)
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Can you post some picture. Did the screws that you used to wall mount it cut into any cables / circuit board?
      • WannaTheater
        • Jun 2017
        • 18
        I will try to get some pictures, but inside looks brand new. No screws pierced anything, nothing burned, very clean. TV was purchased in around 2012 or 2013, with minimal use.
        I just managed to get the self-test to run, and it shows everything OK.
        (everything on the remote and menu seems to works fine, but I have to do things fast.. I only get about five seconds after turning the TV on before it shuts down). Then I have to unplug, plug back in, and start again.
        • diif
          • Feb 2014
          • 6978
          • England
          So the TV worked until you hung it on the wall ?
          Not the first time i would have seen a TV damaged from using screws that are too long in the VESA mount or stand.
          As Dick says, take the back off and post some photos.
          • WannaTheater
            • Jun 2017
            • 18
            Diif- I cannot be positive that the two are related. I had not turned the TV on in 6 months. I should have tested it before I hung it up-
            • WannaTheater
              • Jun 2017
              • 18
              Just checked- There is no way for the VESA mount screws to do any damage- They have their own mounting holes on the chassis, and are inches from any electronics or cables.
              • WannaTheater
                • Jun 2017
                • 18
                Here is a link to 4 photos. The fourth shows how the the right half is dark. From the self-test, it looks like it reset the TV back to factory. Note, I took this photo right before the TV turned itself off.
                https://get.google.com/albumarchive/...OjemaHg_fzArQE
                Let me know if you cannot see the photos-
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  I wonder if you have led(s) failing. Can you measure the voltages on the pins of the connector going to the leds. Looks like it uses edge lit leds.
                  • WannaTheater
                    • Jun 2017
                    • 18
                    What is odd is that the all the LEDs light up initially, then one side shuts down, then they all light up again, then one side shuts down, etc. This makes me think it is not the LEDs, but the circuit driving them- I assume that when an LED fails... It FAILS completely (i.e. won't come on). It is also odd that the TV is shutting off. Much of what I have seen with LEDs failing is that the TV stays on-
                    I will try to measure voltages if possible-
                    Also, my assumptions may be wrong!
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      When the leds light they heat up and then can fail and this just repeats. Whether or not the TV shuts down is dependant on how the set is programmed.
                      Also if it's been in the garage for months and you have any moisture, it could be that the connector to the led strip has some corrosion on it and needs cleaning.
                      • WannaTheater
                        • Jun 2017
                        • 18
                        Ahh. Thanks. Odd question- Should I swap the two cables to see if the problem follows the cables?
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          That would be the quickest test.
                          • WannaTheater
                            • Jun 2017
                            • 18
                            Unless I swap the wires in the header, I cannot easily switch them (I have not disassembled the panel).
                            When measured to chassis ground:
                            Pin 3 (LED1) is 46Vdc
                            Pin 6 (LED4) starts at 46Vdc then drops to 1V quickly
                            LED2 and LED3 are not connected.
                            When I disconnect the panel from the Power supply board, both pins 3 and 6 are +5Vdc.
                            • WannaTheater
                              • Jun 2017
                              • 18
                              Continuing to experiment:
                              1) I swapped the two pairs of wires in the header- No difference
                              2) With the LED header disconnected, the TV still cycles through and shuts itself down, leaving the 1 blink red LED
                              3) I have tried with one pair disconnected, and then the other. TV still shuts down.
                              If the TV is still shutting down while the LEDS are disconnected, wouldn't that imply there is another protection shutting it down?
                              I am unsure of what the panel inverter is (per 1 blink code).
                              • tw2005
                                • Oct 2011
                                • 6458
                                You'll probably find a number of individual LEDs have failed or maybe shorted enough for the cct to detect and shutdown which would explain how it lights up and then turns off.
                                You're probably not going to detect this or see unless the panel is disassembled or if someone knows hoe to meter it to spot a difference.
                                Disconnecting is simply just going to present an open cct which the controller board I'd expect to recognise as a fault too.
                                • WannaTheater
                                  • Jun 2017
                                  • 18
                                  After disassembling the panel, here is what I found:
                                  - There are two LED strips at the bottom of the TV- One for the right half, one for the left half.
                                  - When the TV is powered on, they both turn on. Then the left one turns off (the whole strip). This repeats twice more, then the TV turns off.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    So what are you saying? There is only a single line of leds at the bottom illuminating the panel?
                                    Maybe double check all LEDs are lighting, I know when I did a 50" at first glance it looked like they were but it multiple strips and I think 2 leds were out and that was enough to shut that TV down. I did not pick them at first the light was so bright.
                                    sorry if I lead you astray
                                    • attainteddragon
                                      • Apr 2013
                                      • 764
                                      • australia
                                      i normally film it as they light and then go out, then play it back frame by frame to identify bad led's.
                                      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                      • WannaTheater
                                        • Jun 2017
                                        • 18
                                        Yes- There are two LED strips running along bottom.
                                        Additional photo attached:
                                        I took video, slowed it down, and although it is difficult to be 100% sure (due to brightness), I do not see any LEDs out.
                                        At this point, I am about 85% sure this TV is going to the trash
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • Jacksoft
                                          Panasonic Viera TX-P46G10E 11 blink even after fan replacement
                                          by Jacksoft
                                          I have here a Plasma TV TX-P46G10E that before had a problem where it had issues with 11 blinks (FAN SOS) BEFORE starting normally. After that it works for all day long.
                                          It had some bad cold solder and I remade them all. After I replaced a fan that was half-dead (no RMP signal from the respective pin, but ok with 9V).
                                          Now the TV power up instantly and works perfect... only without the backplate!
                                          If the backplate is placed on the TV shutsdown after about 10min and start blinking with the 11 blinks. If I shutdown and re-powerup it starts blinking after a bunch of...
                                          11-26-2023, 07:22 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • howardc64
                                          LG 49UJ6500 LCD panel lighter band that goes away
                                          by howardc64
                                          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                          02-19-2023, 12:13 AM
                                        • triplefour
                                          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                          by triplefour
                                          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                          tcon is built into mainboard.
                                          Only one cable goes to panel boards.
                                          there is a cable from one panel board to the other that links them.
                                          cost cutting measure that results in us having harder time to diagnose.
                                          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                          07-28-2022, 07:59 PM
