I have a UN60D6420UFXZA that has a strongly suspected main board issue -I posted in another ongoing thread about whether I might be able to use a similar one that is from a UN60D6000SF, that board and mine both have the number BN41-01587E right into the board,, mine was labeled as well with BN97-06022C as well.
Checking various sites online that sell boards I have come across cross referencing that says that the number BN94-05115A has compatible numbers ending in C,D,and E which can be substituted. The number for Samsung tv UN60D6000SF uses a main board with the number BN94-05113F which apparently can use one of the other boards, such as D and E suffix.
ShopJimmy and others show this as possible, I did notice that the 6000SF is not 3D capable whereas the 6420UF I have is, would that make a difference?
I see two of the F boards for a lot cheaper than the more common E and am trying to find out if I can use it. Anyone have knowledge of whether this is possible?
The boards all have the same configuration and connections, another model that usually has the E board is UN60D6450UF. It gets a bit seemingly complicated!
I am hoping someone here can give some advice. I posted this separately for more exposure.
