Another Storm - Another Issue - Panasonic TC-P60GT30 - No HDMI Inputs
  • J_Kane
    • Sep 2017
    • 18
    Hi guys,
    So I am having a new problem with my beloved Panasonic TC-P60GT30 Plasma.
    We had a major wind storm this weekend and we lost power and cable. The cable went out first and while I was out working, the wife called and I had her try the Xbox source as well and she said that didn't work either. Then a couple hours later the power went out. The TV is on a surge protector.
    I work in a utility company so I was out 18 hours a day and didn't have time to troubleshoot it. However, when we gained power back overnight, I woke up and just for shits tested out the TV by using my chromecast and streamed a YouTube video just fine to it. Picture and sound worked great.
    Now, a day and a half later, I can't get any input from any of the HDMI ports. I tried all different sources (xbox, cable, chromecast) with no luck. They all have output too as I verified on my other small TV I brought down.
    FYI, last wind storm I lost my TV and it gave me a 14 blink code that ended up being the main board needing to be replaced. Here is the reference link if interested... - https://www.badcaps.net/forum/showthread.php?t=64827
    The TV picture seems to be fine, I plugged in a SD card and I was able to watch a video perfectly.
    Unfortunately it is not giving me an error code. I tried to unplug for an hour and also rest to factory defaults with no luck.
    Anyone have any suggestions? Another main board I assume?
    Thanks for all the help!
  • tw2005
    • Oct 2011
    • 6458
    Re: Another Storm - Another Issue - Panasonic TC-P60GT30 - No HDMI Inputs
    Originally posted by J_Kane
    Hi guys,
    Yes it would look that way. No, it won't produce error blinks for this. HDMI are quite vulnerable in storms.
    To tell a story I picked up a late model Panny LED Smart TV that had a dead PSU from a storm.
    Ran perfect for first 24 hrs, then HDMI ports quit then DEAD processor. all that happened fairly quickly after a startup next morning.
    From what I've seen most of these boards the HDMI appears to be integrated into the main chip. But if it has a separate chip for HDMI then I've had success replacing that and getting HDMI back but only on two boards .
    IC4700 is a TMDS361B HDMI switch. I'm not convinced replacing that will fix anything if all ports are bad. I suspect that allows 4 HDMI ports to be available as the other 2 ports appear to go straight to the main chip.
    Beyond my knowledge, someone else can fill the blanks on that one.
    May be worth a shot if cheap part and you have the skills to do it without damage.
    http://www.ti.com/product/TMDS361B
    • J_Kane
      • Sep 2017
      • 18
      Thanks for the reply. I will probably just order another board if I'm lucky to find one again!
      It seems like it is trying to connect because when I switch on a device the No input message disappears and goes black but then the message comes back a few seconds later.
      How could I prevent this? I blamed the cable box last time as that was dead too, but the cable box seems fine now. FiOS seems to be the only way I guess!
      • tw2005
        • Oct 2011
        • 6458
        Look I'm not sure if you can or how successful but anything that gets a spike and is connected to the TV can do damage whether it be antennas or the the cable box. There maybe something available but I'm not familiar with cable TV so again someone local may know. I've seen big power boards with ethernet and coax points fitted for surge protection, never used or know how reliable that may be.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Run an earth wire from your outlet (or better, main panel if it's close, but this is not mandatory) to the outer braid of the coax cable at the input of the cable box. This will prevent high voltage developing on the coax and discharging into your TV. Most modern cable boxes use unearthed power supplies, so their only path to earth ground is thru your TV. As you have experienced, this is not a good idea and will lead to issues during a storm or large power surge. Earthing the coax at the input of the cable box gives any current a return path before your TV.
          I did this after fitting a second main board in a lady's LG plasma, CPU went short (again) due to a surge that went thru the HDMI port, from the cable box. It is been over 1 year and it hasn't failed again.
          A working TV? How boring!
          • J_Kane
            • Sep 2017
            • 18
            I was thinking of that. I think I will plan to do it now! I also plan to run the coax through a surge protector as well. Should have done it after the last incident, but never ordered one...
            Thanks for the reply, I'll check back when I get the new main board installed!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Don't need surge protection on the coax, it might mess the signal up, especially if you're getting 1080p content and/or internet thru the cable box as well.
              Just earth the braid and you will be fine. The cable company is supposed to do that at their panel, but they rarely bother over here - guess it's the same on your side of the world.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                D
                Sounds just like the outlets in colonial and Victorian-era houses in the U.S., LMAO. (It's common for northeast U.S. outlets to not have a ground connected, and my UPS will let me know if that's true for the outlet I plugged the UPS into...)
                On February 24, 2018, my family moved to the first "new-for-northeast-US-standards" house they had, IIRC! (Looks like the original portions were built in 1980, my birth year and other parts, very likely the living room, which has a cathedral ceiling, was built in the 1990s or the late-1980s, if not the 2000s... The boiler is a Weil-McLain from what looks like 1998 or near there... (but I dunno about the oil burner, it could be from the original building construction for all I know)
                My family used to rent an apartment in a Victorian or colonial-era house! So electrical issues were common, such as almost everything being tied to one circuit, LMAO! (not just the style, the era as well!)
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Pay attention to the white suffix sticker on the board. It needs to match with your old board. Otherwise you might buy a EU board that wont work in your tv.
                  While the tv is open it's good to tighten all the screws.
                  TNPH09..... TXN/S.
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    before tightening the screws - sand down the pads on the YSUS board (SC board) and the panel - then make sure the screws are tight. This is a main problem of the SC board going bad on these sets.
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • AquaMan Ua
                      Problem with PANASONIC CF53 laptop after changing BIOS settings
                      by AquaMan Ua
                      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                      05-17-2025, 09:40 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      I happened several times, in the search for help from the web, to consult this very interesting forum.
                      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                      Having said that I come to the gist of my post on the forum as the title suggests.
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • aa10aa10
                      Panasonic Toughbook CF-33 mk1 BIOS repair
                      by aa10aa10
                      Good day,
                      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                      01-21-2025, 06:13 AM
                    • Alain Renteria
                      LG OLED77G2PUA Not Powering On After Storm
                      by Alain Renteria
                      Got it for free on marketplace because it stopped working after a storm.
                      When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                      The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                      Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                      11-25-2024, 11:11 PM
