55PFL5505D/F7 image upside down and mirror
    Tv on bench is a 55PFL5505D/F7 LCD
    Donor tv is 55PFL7505D/F7 LED
    Hdmi ports on mainboard fried,found this 7505 model with identical mainboard with cracked screen.
    Swapped out the mainboard,now picture is upside down and mirrored.
    062596+menu followed by diversity code should correct panel. Then 062598+info should get you into sam menu.
    I don't have the info stickers on the panel that should show those codes.
    Better yet,can't even get those menus to show up with the original remote.
    Question now is: Would it be easier to just swap the eeprom? And then,what chip is the eeprom on this board.
    Or how do I set this up correct in the service menu?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    Re: 55PFL5505D/F7 image upside down and mirror
    Service menu-mirror mode, set to on.
      PHILIPS-1
      # Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
      or
      # Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
      or
      # Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
      # Turn the TV off to exit the Service Menu.
      PHILIPS-2
      * Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
      or
      * Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
      or
      * Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
      * Turn the TV off to exit the Service Menu.
      PHILIPS-3
      * Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
      or
      * Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
      * Turn the TV Off to exit the Service Menu.
      PHILIPS-4
      * Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
      or
      * Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
      PHILIPS-5
      * With the TV off:
      Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
      To Factory Mode:
      Step 1 : Select the source "PC" and then turn off LCD-TV.
      Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
      Press "menu"button and bring up factory mode indication
      L7.1A CTV Service Mode
      With special service remote control. Or short M25, M25
      on board and then switch on TV. Exit: st-by.
      Philips Y6 CTV service mode
      Use the standard remote control an key in a special sequence 0 6 2 5 9 6 followed by pressing the 'MENU' button. If the main menu also appears with the service menu just press 'MENU' again to clear it.
      Philips VR220 service mode
      Reset to factory settings Disconect from the mains power supply. Press and hold the STANDBY/ON button on the device and reconnect to the mains power supply.Release the button when 'OSD' appears in the VCR display
      RELATED SERVICE CODE / MODE
      AIWA AKAI AKIRA BUSH FUJITEC CHINA GOLD STAR HITACHI HONDAI ICHIKO JVC KCL LG MAGNAVOX MITSUBISHI PANASONIC PHILIPS SONY SONY-2 SAMSUNG SANSUI SANYO TCL TCL-2 TOSHIBA VIDEOCON
        So with 062596 info I got into the menu.
        I got to this page (see pic) and it shows the current panel thats selected and then the options you have. I need the ccfl 55" option I'm guessing but I have no idea how to select that one. Pushing random buttons so far doesn't do more then getting me stuck in a color display loop thats almost impossible to get out of.
        I thought I was smart and DL the software update for the 5505 but the 7505 caught on to that and didnt accept the update
        2nd pic I turned it around in paint to make it easier to read lol
          Maybe try control+alt+up arrow.
            There are no control and or alt button on my remote
              Ok, thought that looked strange, they mustve been on a pc.
                Be very careful, if you change any of the wrong items you can damage the tv beyond repair. You are looking for the setting called either Flip, Mirror, or Vertical flip (v flip). You'll change that to the opposite of what it is set on now.
                  I have an older lcd philips, I can't find anything related to picture flip, I know it's pretty simple in lg tvs, can't seem to find any definitive info on flipping a philips screen tho. Curious now, I will find out, even if I have to go to the dark web, lol.
                    http://www.supportforum.philips.com/...creen-rotation
                    This guy says you can't rotate image, I think he means in menus, starting to believe it.
                      I guess if all else fails you could do the pc screen flip and use it as a big ass monitor.
                        What is the LCD panel number? Sometime it has control line to set mirror mode.
                          what is the lcd panel number? Sometime it has control line to set mirror mode.
                          +10
                            These are the stickers on the panel. Hope they make sense to you as they are not making sense to me lol
                              https://www.usa.philips.com/c-f/XC000010530 another reset procedure, hard to tell if it will work.
                                Well,I'm not looking to reset to default.My problem is that this mainboard is from a 7505 LED model that I'm using in a 5505 CCFL model. If I could only flip the image I'd be golden
                                  lcd panel specs link
                                  http://www.panelook.com/LTA550HJ01_S...iew_12171.html
                                    Did you try naming it 5505 in menu? might brick it tho.
                                      So,I now have this thing stuck in a permanent loop of showing all the colors.
                                      Which IC would be the eeprom,I think the fastest would be to just swap them out and be done with it.
