Bush DLED40127FHDCNTD - Software dump
  • leo-saphira
    • Feb 2015
    • 32
    Have one of these Vestal built dumps in the workshop at the momemt with a faulty mainboard. I also have a working one as well that is currently up for sale - both sets have the same part numbers on the main board and is there a way of extracting the firmware off the working set onto USB? Then to install onto the corrupted one?
    Re: Bush DLED40127FHDCNTD - Software dump
    You can look into editing the boot configuration file on an update USB.
    These vestel sets use u-boot which is open source software. It is what loads the flash memory correctly.
    It is possible to edit the u-boot txt file to make it copy the flash to a USB drive, instead of load the flash image. However, do be aware, that when messing with things like this, it is possible to brick your working set, if you get a command wrong.
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Mephysis
      DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
      by Mephysis
      Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
      I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
      03-27-2025, 02:34 AM
    • dell_bios
      Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
      by dell_bios
      I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
      The board has three SPI flash chips:
      - W25Q64FV (main BIOS)
      - W25Q32FV (EC/TPM)
      - W25X10CL (configuration)
      I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
      The dump contains protection that needs to be removed.
      If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
      I’m also happy to share my dump for comparison if needed.
      Laptop model: [please specify, e.g....
      10-16-2025, 04:28 PM
