if there no change. i advice you to solder out the both transformer near the R you replaced it and check them, they may have bad inside pin connection .. i faced this under other platform
What is the voltage across C48, that voltage comes from the circuit that had the open resistor
Then, using hot ground (TP21) check the voltage on the opto (ic1) pins 3 & 4 (or zd2)
Voltage on C48=
Voltage on ZD2 anode=
voltage on ZD2 cathode=
RF1 was open, did you check r39 (0Ω). R38 (51Ω), R10 (51Ω) and all 5 diodes
I know no one wants to believe me but this power supply can operate in standby (burst mode)
Voltage on C48=
Voltage on C48= pulses between 15 and 19.6 volts
Voltage on ZD2 anode= 0 volts
Voltage on ZD2 cathode= pulses to 2.5 volts
Check the voltage across C56, then using hot ground check the voltage on D2 cathode, then ZD3 cathode
That voltage on C48 may be coming from the ic's startup cell
When U1 starts, the internal startup cell will produce around 20v on pin 6 (SUPIC), this voltage needs to be sustained from an aux source, In this case that is the VCC supply of T1, Pins 5&6 diodes D4,12,18,19, charging C56. That voltage goes through diode D2, R38, clamped by ZD3 and through R10 to U1 pin6
zd3 cathode is connected to R10. But I can see there is not enough voltage produced on C56.
That 19.6 is coming from U1 and not being produced by T1 VCC winding, check that the winding pin 5~6 is not open.
This could just be because the power supply IS in standby.
Check the voltage (cold side) on IC1 pin 1 and pin 2 , pin 1 is likely close to 8 volts (comes from 13v supply) pin 2 should be less, Check the voltage across pins 1 & 2, if it is 0 volts the led in the opto is not lit.
Find Q1 and short the collector to ground (C is connected to R57) that should turn on ic1
may be..LOL or yours hair dryer u used before was soldering hot air gun..LOL spare time and replace this boards but be alarm that you will just go back to first point to read 80 13 volts only
At least then, it didn't tic. I'm using a good digital meter.
So with Q1 collector connected to ground, you had 1.5v across the opto pins 1&2 did the power supply give you 13 & 80volts? if not we can confirm that the opto is working by checking the:
with 1.7 volts across pins 1 & 2, the voltage on ZD2 should be very close to the same on anode & cathode.
Do you ever get the full 13 & 80 volts like you did before?
so when you have 1.7 volts across pins 1 & 2 of the optocoupler (led side), the photo transistor side (pins 3 & 4) should be conducting and close to the same voltage on each pin so the same voltage should be on both pins of the ZD2 diode.
You could have a bad optocoupler. Whats the number on it?
You could monitor either 13v or 80v supply line and short pins 3 & 4 of the optocoupler, if the opto is at fault the voltage should come up to or slightly above spec.
