Vizio M492I-B2 Sudden Pop-Off
  • treebeardicus
    I've had the Vizio M492I-B2 since February 2015. It's been a good TV set (not to mention the apparent unicorn that has more than 3 HDMI ports) since then...until yesterday morning. I'm up, having my coffee, working my way down a YouTube rabbit hole when I hear a POP sound and lose both picture and sound.
    Initially, I thought I lost power. Modem/router lights still on disproved that immediately. I thought I'd try both the Roku remote and the original Vizio remote--no dice. I attempted to manually power on the unit--nada. I decided to unplug, wait 30 seconds, and replug. While I was waiting to replug, I noticed the smell of something burnt. Not good, I thought. I decided to go through a full hard reset--unplug, hold power down, replug--and nothing happened. Standby light doesn't even flicker. Only thing that I sensed was the smell of burnt plastic.
    I crossed some things off my list, including the flashlight test to see if an inverter was an issue. I checked the screen as best I could, and I don't think that whatever the pop was caused any damage. The Internet--which of course is always 100% true and never has any false information whatsoever --tells me this is the Vizio Pop of Death.
    My wife and I had been talking about upgrading the TV anyway, so we took this as a sign to do so. But I'm thinking I'll be able to repair this one and wall mount it in a separate room. Based on lots of reading--including help from this forum post--I'm thinking I should try to replace the power supply first. Rather than pore over each component to see what needs to be replaced, I think I'll be in and out quicker with a board swap.
    Hat tip to the original post on this model, and to this forum in general. If anyone has any tips for board replacement, I'd gladly welcome them. It looks simple enough--some screws and pin connections--but anything I think is simple is usually trickier than I initially estimate.
  • nomoresonys
    • 12216
    • U.S.
    Re: Vizio M492I-B2 Sudden Pop-Off
    Need to investigate with a pop and a burning smell you should be able to see some physical damage on one of the boards.
    • treebeardicus
      nomoresonys--
      Thanks for all the help, especially the videos. I'll probably not get around to replacing the board until another week or so. I'll dig into these videos to make sure I'm taking all the proper precautions.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8286
        can we see some pictures of your boards?
        • R_J
          • Jun 2012
          • 9579
          Have a look at the power supply board, and inspect IC901, that is the standby ic and it might have blown.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • howardc64
            Vizio SmartCast TV software bug that looks like hardware
            by howardc64
            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
            11-16-2024, 05:17 PM
