insignia ns-55l260a13 buttons not working
  • Eel_dahc
    • Apr 2017
    • 18
    Hello everyone.
    I bought a used insignia ns-55l260a13 that they said didn't work. It was $20. But it does work as I turned it on and left it on for an hour. The only thing that I found that's a problem is that one volume, one menu and one other button don't work. I took out the button board and cleaned that up as one button for sure wasn't working. After cleaning they seemed fine with the meter. Then I noticed a short, with the button board unplugged between KEY1 and ground on the connector so I followed the trace until I found a cap (red dot) that seems shorted.
    Do you think I would be safe just popping that off and see how it goes? I'm not a pro at this.
    Re: insignia ns-55l260a13 buttons not working
    Well, remove the suspect cap and see if the shorts will go away or not, if it does then use the cap meter then you check the capacitance of the cap to the right after removing it to test the capacitance.
    • Eel_dahc
      • Apr 2017
      • 18
      Took the cap out and a resistor that seemed shorted too. Those weren't it and the traces then ran under the metal shielding to one of the processors so I stopped there and just put it back together. It works with a remote. Thanks Budm
      • lafilipczyk
        lc 80le632u - Lamp error - TV working after counter reset via buttons
        by lafilipczyk
        Hello everyone, I just got my hands on a Sharp lc 80le632u TV that initially had the 1 short, 1 long blink sequence. That indicates a lamp error, however if I follow the isntructions to reset the error counter, the TV starts correctly: no missing LEDs everything lods just fine.
        I went through the process to get to the diagnostic screen, and got this ( attached).
        Since all LEDs are working correctly, and the TV seems to load fine after reset, that tells me that the power board and the LED strips are working correctly. Could this be a main board issue?
        Any...
        07-29-2024, 11:00 AM
      • JakeShaw
        Sony HTG700 soundbar buttons not working.
        by JakeShaw
        Remote inputs are great and functional, but after 2 mainboard swaps the buttons have stopped working altogether, seemingly. The remote is required to power on and reset, but no amount of messing with it has gotten anything to respond.
        Checked plugs, everything is good, unhooked it and tried a different main, nothing. As everything else is functional I have no clue what else to do.
        Even replaced the button board itself, still no response.
        06-12-2023, 08:19 AM
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
      • obelix24
        Macbook Air 2020 (a2179) - touch id not working
        by obelix24
        Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
        I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
        02-09-2025, 12:57 PM
