Please help me fix my beloved Panasonic TC-P65ST30
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Please help me fix my beloved Panasonic TC-P65ST30
    The value of that capacitor isn't critical. I would check the startup resistor of the power supply controller.
    A working TV? How boring!
    • Ren01
      • Aug 2021
      • 33
      Originally posted by Davi.p
      Yes for the 1 & 2 pins, but since there is a source pin there is / are also a 2w less than 1 ohm resistor connected to source or many smd resistors in parallel (1/2 ohm). Why you have guessed 470pf?
      There is a ceramic resistor beside the blown capacitor around 0.32 ohms. It seems to still be good, but my multimeter is not accurate enough to say for sure.
      I had to guess the blown capacitors value by comparing the size of what was left with the rest of the capacitors on the board. Not very scientific haha.
      • Ren01
        • Aug 2021
        • 33
        Which capacitor value isn't critical? C404 or c411, thank you!
        • Ren01
          • Aug 2021
          • 33
          Looking closer at the pcb, I think c411 is in parallel with the ceramic resistor Davi.P mentioned. That would explain the short right?
          • Ren01
            • Aug 2021
            • 33
            Would it be stupid to place some Arctic MX-4 thermal grease (non conductive) between the mosfet and the heatsink?
            Sorry, I have so many questions!
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4425
              • Italy - Milan
              #26
              It is not that resistor, it must be non flammable round type, and burnt... it must be connected to source pn, follow it... thermal grease is a must..
              • Ren01
                • Aug 2021
                • 33
                Thank you! The mosfet originally had no thermal grease or thermal pad, I wonder if that's what caused the failure...
                Anyways, the round resistors on the top of the board, (didn't check the surface mount on the bottom) seem to measure fine.
                I guess all I can do is wait for the new mosfet to arrive in 2-3 weeks. Thank you again for all the help! I'll report back if the repair is successful or not then.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4425
                  • Italy - Milan
                  #28
                  I don't advice to you to sleep quietly waiting, check the datasheet for the typical application circuit, if connected to the source pin there's a small value resistor to ground, then you surely have to change that resistor...
                  • Ren01
                    • Aug 2021
                    • 33
                    I think I found the resistor you mentioned, but previously you said it wasn't it? Can you please confirm. I've attached the following:
                    1) The data sheet example circuit showing there must be a resistor attached source, R2
                    2) The example value of R2
                    3) A picture of the ceramic capacitor that I think is R2 (can't measure it well resistance too low)
                    4) A picture of the opposite side of R2 facing the side where the ceramic capacitor blew up showing a slight black mark.
                    5) the back of the of the PCB showing that Source and ground are both attached to each other via this resistor in parallel with the capacitor C411.
                    Sorry for all that. Are you saying I should replace this ceramic resistor?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4425
                      • Italy - Milan
                      #30
                      Ok maybe that resistor is good, But with the shorted mosfet, where the circuit is open? if not it can catch fire..
                      • Ren01
                        • Aug 2021
                        • 33
                        Definitely don't want a fire! What do you mean by shorted mosfet? When I removed the old mosfet, drain and source was shorted on it. Should I do more than replace the mosfet?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4425
                          • Italy - Milan
                          #32
                          I mean, if mosfet is shorted then it flows too much current on the circuit, so something other must blow, in all the situations i've seen the critical one is the resistor that is made to break without burn, you don't even have a blown fuse, so where is the open? Without opening something must burn..
                          • Ren01
                            • Aug 2021
                            • 33
                            The capacitor that blew up was between the source and drain. Could that be it?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4425
                              • Italy - Milan
                              #34
                              No. But let's make things short, measure ohms between source pin and primary ground..
                              • Ren01
                                • Aug 2021
                                • 33
                                Source to ground resistance measures at 0.9 Ohms. My meter when touching the two probes together measures at 0.7 Ohms.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4425
                                  • Italy - Milan
                                  #36
                                  ok, strange thing but replace only the chip..
                                  • Ren01
                                    • Aug 2021
                                    • 33
                                    Thank you!!!
                                    • Ren01
                                      • Aug 2021
                                      • 33
                                      So, new mosfet from China arrived with new caps from digikey. Replacements parts were soldered in, but still no power at all
                                      Maybe it's a fuse?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4425
                                        • Italy - Milan
                                        #39
                                        You told that fuses are ok... Measure D pin of I401, if 320 or 160v is present Replace R403 and check again I401 for short on D-S
                                        • Ren01
                                          • Aug 2021
                                          • 33
                                          Sorry it took so long to reply, life kept me busy. No short from drain to source and double checked all pins soldered correctly. Not sure I can check the voltage while plugged in with my cheap meter safely. Since drain pin is right above the heat sink, it would be easy to short. I could buy a replacement resistor on my next order instead.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • aa10aa10
                                            Panasonic Toughbook CF-33 mk1 BIOS repair
                                            by aa10aa10
                                            Good day,
                                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                            01-21-2025, 06:13 AM
                                          • Mnawar27
                                            Panasonic CF-H2AU24EF3 bios locked
                                            by Mnawar27
                                            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                            I need help to remove it,
                                            thankyou all.
                                            SN; 2FKCA26876...
                                            11-16-2024, 08:00 AM
