Sharp LC-50LB261U
  • Megan0
    • Aug 2021
    • 28
    • united state
    Sharp LC-50LB261U
    My sharp tv has no picture, when I turn it on the red light indicator blinking 7time, after that it change to blue indicator but still no picture.
    I tired some different outlet - I tried to reset but still has no picture.
    anyone know what is this code? 7time red indicator blinking.
    Thank You.
  • neilc6
    • Nov 2015
    • 1550
    Re: Sharp LC-50LB261U
    Your TV is turning on with no backlights which is a symptom of bad backlights. You can perform the flashlight test to see if you have video. You may see them flash in a dark room.
    • Megan0
      • Aug 2021
      • 28
      • united state
      Thank you for answer, I did the flashlight test and I see all logo, menu, and ....
      what should I do, Should I replace the backlight? The problem can be a loose tcon connection? or bad tcon board?
      • neilc6
        • Nov 2015
        • 1550
        Your TV has bad backlights. Proper repair is to replace them all with new strips.
        https://techhometravel.com/lg-ln-ser...ed-backlights/
        • handsworth
          • Oct 2015
          • 174
          Yes, your backlight(s) are bad. Replace all of them and be careful removing the screen. It may be glued down. I just did one last week but really dont remember if this one was glued.
          • Megan0
            • Aug 2021
            • 28
            • united state
            Thank YOU
            • Megan0
              • Aug 2021
              • 28
              • united state
              Thank YOU
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                This is an easy fix. Replace ALL the Backlight strips with NEW strips. The hardest thing to do is removing and replacing the Screen without breaking it. But it can be done.
                • Megan0
                  • Aug 2021
                  • 28
                  • united state
                  Yes that is good point, I don't have a suction to remove the screen and it a little bit challenging.
                  • Megan0
                    • Aug 2021
                    • 28
                    • united state
                    Hi Guys
                    I opened My tv and checked all SMD LEDs one by one and found 4 bad LED. Do you think the problem will be solved after replacing those bad LEDs?
                    Now I wanna order New SMD LEDs to replace with bad LEDs, But I couldn't find what version of SMD LED is compatible with my tv? does anyone know?
                    Size : 2.8mm x 2.8mm
                    • neilc6
                      • Nov 2015
                      • 1550
                      It is better to replace all the strips with new. All the LEDs have wear and they will eventually fail.
                      • handsworth
                        • Oct 2015
                        • 174
                        Neilc6 is right. Replace all strips with new ones. I have done this series tv so many times and found out the leds have limited life. If you just replace the bad ones, you'll be back doing it again, possibly the next day or day after.
                        • Megan0
                          • Aug 2021
                          • 28
                          • united state
                          Thank you
                          • Megan0
                            • Aug 2021
                            • 28
                            • united state
                            Thank you
                            • roy.zhero
                              Sharp LC50LE752E no picture and backlight, indicator light is lit
                              by roy.zhero
                              I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
                              When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
                              When I hold the force-on-combination it will turn on. It then shows a perfect...
                              09-20-2020, 01:57 PM
                            • binary0101
                              Asus X453SA No Display - Charging Indicator Blinking
                              by binary0101
                              Greetings
                              I got an Asus X453SA for repair
                              Symptom : no display, with charging indicator blinking, with or without battery. Power indicator is steady. When battery plugged in, the current consumption jumps, but the charging indicator is still blinking.
                              Here is the measured power sequence :
                              +3VA_EC +3.3V
                              EC_RST# +3.025V
                              +5VSUS_ON +3.307V
                              PWR_SW# +2.982V
                              3VSUS_ON +3.307V
                              SUS_PWRGD +3.386V
                              +1.05VSUS_PWRGD +1.061V
                              1.8VSUS_EN +1.873V
                              VSUS_PWRGD +3.383V
                              PM_PWRBTN# +1.830V
                              PM_RSMRST#...
                              02-01-2023, 02:33 PM
                            • canadaboy25
                              Sharp LC-60LE920UN LED TV won't turn on. Blinking indicator
                              by canadaboy25
                              Hey everyone, I have a Sharp LC-60LE920UN LED TV that I just picked up. Plugging the TV in only gives a flashing power indicator. According to the service manual, one fast flash and one slow flash means a lamp failure. I assumed it would just be a failed LED so I started testing all of the led circuits. Each circuit lit up when power was applied.
                              I did some searching and apparently there is a way to force the TV on for older models by plugging the TV in with some buttons held. However, this TV does not have physical buttons but instead has capacitive touch buttons. I have tried...
                              03-18-2021, 03:34 PM
                            • bajdik
                              Sharp LC-40LE830E white blinking after wallplug is off
                              by bajdik
                              Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
                              07-21-2023, 09:05 AM
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
