Help finding replacement buck ic for Sony XBR-65X930D
    I know there was a recall for these TVs due to this ic failing so wanted to make sure I got a replacment that was revised? Unless Sony revised the entire board? In any way would like to just purchase the ic from a USA seller if someone could point me in right direction. Thanks in advance
    Re: Help finding replacement buck ic for Sony XBR-65X930D
    Tps54334
      The same ic has again shorted out. Lasted about 8 months. Does anyone know why it keeps failing? I know it’s a known issue with this model. Anyway to prevent it shorting out again?
        Does it run hot?
          Originally posted by CapLeaker View Post
          Does it run hot?
          Not sure honestly. Sony was replacing units for the ic failing so was wondering if they did a design revision or not. Should I put a dab of thermal compound on it as a precaution?
            If heat killed it, I’d put on a heat sink, or look for a better spec’d replacement. Maybe poke around at the IC with an oscilloscope? I would have thought the buck converters are better than the LDO’s, but now I guess not?
            Check the voltage on input. It should handle up to 24V.
