Battery protection circuit chip ID
  • david37g
    • Mar 2012
    • 18
    I have a lithion ion battery that has a bad chip in the protection circuit. The number on the chip is 10AH2. There is also a square box with the letters SC in it, probably the manufacturer.
    The chip is 2 layers, black on the top and white on the bottom. About 1/8"x1/4 inch with a surface mount soder connection on each side. There is an "F" on hte pcb next to it, so it could be a fuse. This chip is connected to the source terminal of a N-channel mosfet TPC8026. Tried to get pictures, but it is too small to show anything in focus with my camera.
    I have googled everything posssible with no success. Any help identifying what it is would be greatly appreciated.
  • Duncanbest
    • Jul 2012
    • 81
    • Taiwan
    Re: Battery protection circuit chip ID
    http://www.dexerials.jp/en/products/c3/sfh0412.html
    • david37g
      • Mar 2012
      • 18
      Thanks, that is it.
      • david37g
        • Mar 2012
        • 18
        Have searched Digi-key and Mouser and can not find any SCP or thermal fuses that match this. Do you know a source?
        • Sanju9078
          • Sep 2021
          • India
          You can check it on AliExpress
          • piernov
            Laptop battery charging circuit
            by piernov
            1. Some theory
            1.1. Introduction
            Almost every laptop has a charging circuit of some sort, that does a few things:
            • Manages switching between AC adapter and battery power
            • Manages battery charging and generates power rail to charge battery
            There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
            • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
            • Narrow VDC (NVDC)
            Texas instrument has a nice overview of these technologies with some more details at https:...
            11-15-2020, 01:31 PM
          • Crrose
            How to test circuit board battery connection.RS-4i sequential stimulator
            by Crrose
            Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
            03-21-2023, 03:55 PM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
          • fab13
            Nintendo Switch lite charging chip heats up and does not short circuit
            by fab13
            Hello everyone
            Small technical problem on a Nintendo Switch lite
            Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
            After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
            When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
            Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
            09-16-2023, 04:59 AM
          • huzo
            HP ELITE X2 1013 G3 weird battery issue
            by huzo
            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
            01-31-2025, 12:09 AM
